I can’t push this article to my Kindle. Could you help?
Thank you!
Thank you!
@fivefilters I can’t look deeper into that at the moment. Just tried a simple
body: //article
in the config (PR1111). I got nearly all the text, but one parapgraph missing and I don’t know why, maybe scripting?
Headline: Tus anuncios, potenciados por la IA
text: Desde hace varios … el fraude publicitario
@Fer, as I don’t speak Spanish, is that paragraph part of the article or just some extra-information. And: What do you mean, you can’t push? Just two paragraphs or really nothing or failure message?
Thanks @HolgerAusB, will take a look.
Just want to let you know: In Wallabag this section is present - with my config
@fivefilters: I found out, that this section is pruned by unknown reason. prune: no was helpful here. I fixed it now.
Hi!
Thank you for looking into this!
I’ve tried to push the article, and everything looks correct. Thank you again!
Best regards
Thank you! It works already. Big thanks to whoever has fixed this
Excellent! Thanks @HolgerAusB, and thanks for the update @Fer!
