I have tried copying the session cookie (djcs_session) from a logged in browser, and while this seems to work with other browsers, it does not work in Postman nor when added to a custom pattern in FTR.
@HolgerAusB I had a look and I’m seeing the same as you, no /amp/ support any more (it just redirects). Previously the /amp/ version would contain the full content. Do you know what the browser plugin is doing? I can’t really tell from the snippet you pasted. Adding a user agent string like that makes no difference in my testing.
I can’t exactly figure out what the javascript is doing to the DOM, but it appears there’s multiple ways to handle the paywall removal depending on the article URL, whether it contains “livecoverage”, or “articles”, etc… It does seem to use amp in some way, but again I’m not proficient in JS enough to tell what it does exactly
