I tried to send a WaPO article using P2K, and it cuts off after the first section. It DOES however preserve the section headings and bullets, which is really great.
@fivefilters, I am not Ana but checked it too. Unfortunately the P2K preview say “Unable to retrieve content”.
The new config works great with self-hosted FTR, while the old one showed less then Ana’s example.
Wallabag also gets all content, but the subheadings missing here. Will investigate this on Monday or Tuesday.
I hope, WP ist not blocking P2K servers… because ftr.fivefilters.net say’s that the WP-domain is on FiveFilters block list by request of source site’s owner.
@Ana if your are using a desktop browser, try to use the plugin or bookmarklet. I am at night shift at the moment, so I can’t test now, if that works.
OK @fivefilters, fortunately it is not a block by WP. I found out that there is ‘just’ a problem with your entry point at www.pushtokindle.com/get-started. Any URL provided here (other domains too), are not passed to send.php anymore, it always results in this URL: https://pushtokindle.fivefilters.org/send.php?url=undefined
when replacing ‘undefined’ manually with the source’s URL it works well.
