Text does not match chapter title in Patreon
Both Chrome and Safari extensions behave the same. When a chapter is opened on Patreon, Push to Kindle extension displays correct title and first sentence, but then previews and sends text from some other chapter. Clicking “View Original Article” shows the correct text. Some chapters work correctly, but most don’t.
Welcome @gbach.
Just to be sure: Your are talking about patreon.com, yes? Or is Patreon some kind of hardware?
Please provide us with a direct URL to an article, which is at least readable with a free membership.
Yes, Patreon.com
Here is a link to Chapter 120 - The 9th Binding, but when I use Push to Kindle, preview shows the title and 1st sentence correctly in the Info box, but then captures text from Chapter 124. View Original Article is correct and does not match. Chapter 110 does the same. Most, but not all, do not work. Thanks
This creator isn’t for free but I found two different ones and I hope that the config I wrote with them also fits your needs.
Please try to re-fetch again and report.
That seemed to work. Thank you.
