It appears that the siteconfig file for t3n.de no longer provides desired results. The changes made previously to bypass the cookie wall no longer work. The extraction result is the message from the cookie wall.
I tried adding http_header(Cookie): t3n_consent=4; to the sitecofig, but it appears to cause an infinite redirect loop.
I would appreciate if you could take a look at it.
