Maybe I misunderstood the help text. I read it that way, that the site-configs are merged from standard and custom subfolder.
But unfortunately this does not work. I have in the custom folder the file heise.de.txt, only with the line http_header(cookie): ssohls=xxx with my session cookie (paid subscription). But FTR does not merge this with the content of the file heise.de.txt from standard folder. Only if I copy the file from standard to custom and insert the one line for the cookie it works correctly again. But this won’t benefit from automatic pattern updates
Am I doing something wrong or have I misunderstood how it works?
This would be by the way also such a case, where one would like to have a function like:
include-conf: standard/heise.de.txt
…which I had already suggested on another occasion.
Alternatively or additionally a new subfolder would be conceivable, which is always merged:
site_config/credentials or
site_config/personal
Hi @HolgerAusB,
That should be what happens. Are you able to enable debug output and paste the relevant part here (the site config loading)?
For my tests I use the URL:
https://www.heise.de/news/Geld-fuer-Elektroautos-Was-der-Staat-2023-noch-beisteuert-7443254.html
This is a free article that can be read in full by non-subscribers.
Before each test I cleared the APC cache in FTR 3.9.11. And by pressing F5 in the browser also cleared browser cache.
Under site_config/standard/heise.de.txt is the original from Github.
If I now set under site_config/custom/heise.de.txt a file with the content http_header(cookie): ssohls=xxxxx, the standard-config is not loaded. Here now the article images are missing and other customizations from the standard-config are also missing. I am a paying subscriber to ‘heise’, the cookie contains my personal credentials aka session-cookie.
If I now delete the config in custom the page is prepared again nicely for free articles, but of course not for the paid ones.
The whole thing works only if I copy heise.de.txt completely from standard to custom and insert my cookie header there. Unfortunately, I now have to manually insert my cookie every time there is a change of the default config on Github.
Debug-Log:
. looking for site config for heise.de in custom folder
* ... found site config (heise.de.txt)
* Adding site config to APC cache with key sc.heise.de
* Cached site config with key heise.de
* . looking for site config for heise.de in standard folder
* ... site config for heise.de already loaded in this request
* . merging config files
* Adding site config to APC cache with key sc.heise.de.merged
* Cached site config with key heise.de.merged
* Checking fingerprints...
* No fingerprint matches
* . looking for site config for global in custom folder
* . looking for site config for global in standard folder
* ... found site config in standard folder (global.txt)
...<cut>...
* ......sending cookies: ssohls=xxxxx
Checked this with annother news site and placed a config file fr.de.txt only with a #comment inside to the custom folder. The config from standard then is not loaded.
