I had bought business license for Feedcreator and tried to installl it
When I tried to combine two RSS feeds using From feeds Tab/
Fatal error: Call to undefined function mb_internal_encoding() in /home/pressr/public_html/feedcreate/checkurls.php on line 3
Looks Like it needs some additional module or extension
Please provide me information what PHP modules modules should be installed for Feedcreator to work?
Php 5.5 isnstaled and works correctly
Hi Boris,
Thanks for letting us know about this - we’ll make sure to add a compatibility test file so users can check if their servers are compatible or not.
In this case, you need the mbstring PHP module installed and enabled. If you are not managing the server yourself, you can ask your host or system administrator to install and enable the mbstring module for PHP. It’s often available by default, so most users don’t have to manually enable it. Sometimes it’s available as a package you can install called php-mbstring.
Please let us know if you still have trouble.
