Hi, this article:
https://www.reuters.com/investigates/special-report/global-art-banksy/
is not extracted well.
It might be worth taking look at. Thanks!
Hi, this article:
I made progress with fetching your article. But I need more time to check the new configuration against other Reuters articles, before I upload the config changes. Maybe Monday or Tuesday.
Stay tuned
I wrote a new config for reuters.com, which is working with wallabag/wallabagger, but not yet for PushToKindle.
@fivefilters as far as I can remember, you are using a different config for reuters, than the one in the repo. Unfortunately you Mac UA doesn’t work any longer.
Could you please upstream my latest changes from reuters.com.txt to P2K (maybe except the UA line)
@HolgerAusB Sorry for the slow reply. Will look into this again and let you know.
