Hello,
Thanks for your ongoing support
I need to remove the following href code without usig “//a” as “//a” removes videos and images too!
التقاط صورة تجسسية للنسخة المحسنة من اوبل زافيرا لأول مرة
you can check link here :
http://www.arabsturbo.com/content/صور-اوبل-تكشف-النقاب-عن-موكا-اكس-الشبابية-ذات-التصميم-العصري-21602
Can you help me with that ?
If your questions is about removing the element completely, including the text within, you can do so and restrict removal to certain a elements by providing conditions. For example:
strip: //a[contains(@href, ‘something-unique-to-the-URL’)]
or
strip: //a[contains(., ‘something in the link text’)]
If you want to remove only the link but preserve the link text, that’s not currently possible with a site config file. But it’s possible to tell Full-Text RSS to remove all hyperlinks while preserving the link text by using the ‘links’ field. Simply set it to ‘remove’. Or use &links=remove in the querystring.
Thank you working great as needed.
Mohammad
