My question exceed max length of 5KB, so posting it here : http://pastebin.com/sCDKQ6AW
Hi Samuel,
Sorry for the late reply to this.
Unfortunately GUID rewriting is not something you can enable/disable in Full-Text RSS. But it’s also not something we’ve done deliberately, so I’ll have to see if we can preserve the original value in the next update. Thanks for letting us know. If you’re using the self-hosted version, you might be able to try and fix it yourself by examining and modifying the source code - although we can’t really help with that ourselves.
