Using the browser extension, the following page is cut off less than halfway through:
The last sentence that shows up on my kindle is
“But when I asked her for a refill sooner than usual, she didn’t bat an eye.”
Hi @VicM,
thank you for reporting this. I just wrote a site config for vogue.com and voge.co.uk please try again and report us.
As I am not at home at the moment and not allowed to install the fine P2K plugin here, I could not test the behavior with plugin. But I believe it should working, at least for short articles as your example.
For longer articles you might see just a few paragraphs. The rest is hidden behind some kind of JavaScript-LazyLoad-Voodoo. But If you load those articles with your browser, scrolling down till the end of article and then using the plugin, that should fetch all the content. So is my hope.
Example: The wedding of Gaby and Zach
Of course, nobody would try to send an article with 93 images to his/her Kindle, but maybe wants to generate an EPUB or PDF
It works! Thank you so much for taking care of this so quickly ![]()
