In this article only part is extracted:
that is the case for all the articles in onb blog section: https://www.onb.ac.at/mehr/blogs
Servus @sennierer, willkommen im Forum.
I wrote a config for the domain onb.ac.at which should fix the problem. Please try again and report any additional problems you find for onb.
Holger
Thanks! Works perfectly!
