@fivefilters I can’t fix that without a test system. I tried with my wallabag and wallabagger browser addon, which works similar to P2K addon, but its weird.
NYT uses several different layouts and therefore there are already 7 different body selectors in the config. With a concatenating one at first place, which could prevent the following selectors to work.
When deactivating all of them, I got all the real content, BUT I also get a large section with consent stuff, cookie management and other things, not belonging to the article text. And sadly, it is above the real content. I used the giftcode-URL.
I tried several selectors that should work, but the result is allways the same:
# tested only one body selector at a time
body: //main[1]
body: //main[@id='site-content']
body: //article[1]
body: //article[@id='interactive']
body: //section[@id='best-books-21st-century']
# and even, to test only for the first book:
body: //section[@id='book-100']
and of course, I tried to strip the overlay fringe, but that is also not working.
strip: //script
strip: //*[contains(@class, 'overlay')]
strip_id_or_class: fides-overlay
strip_id_or_class: fides-modal-footer
strip_id_or_class: app
When using the plain url without the gift-code part with an unlocker plugin, I don’t get the consent stuff, but a literal json/css block above the content: {"css":["https://static01.nytimes.com/new.... And the following content also contains all 100 books, instead of only the first one, when using body: //section[@id='book-100'] which should only result with the first book.
I don’t know, how P2K is doing here, but as I need to wait for the next full hour, before I can check the result after I uploaded a new version, that could cause problems with other users/customers on regular NYT pages for hours or days.
