Is it possible to make some code improvement to avoid column-break or page-break between article-title and article-content?
Well you can see in example:
This is made by PDF Newspaper, I’m very satisfied and it is very nice, but column-breaks, and page-breaks inside articles destroy good work.
I solved cover-image, putting code in subtitle, and go inside to define footer text (it will be nice to put that option in config
So, what can be done to avoid article-breaks?
