hi,
i would like to increase the maxitems number to 30 item
any help would be appreciated
thanks
Hi Adnan, you can do this by editing the config file. See http://help.fivefilters.org/customer/portal/articles/223410-configure if you haven’t created a config file yet.
Inside the config file you’ll find an option called $options->max_entries - you can change the value here to 30 to increase the maximum. You’ll then be able to tell Full-Text RSS to retrieve up to 30 items from feeds.
