I’ve been trying to get a feed load images with only partial success. I got some inspiration from the forum and with some of the strip_id_or_class got the image at the beginning of posts to appear. However any image inside the posts still don’t show up.
Here’s the feed on the public FTR: http://ftr.fivefilters.net/makefulltextfeed.php?url=www.hackneycitizen.co.uk%2Fcategory%2Fnews%2Ffeed%2F
Here’s the custom config I created, basically trying to strip all classes mentioning lazy, replacing all elements mentioning lazy and not pruning anything:
The site appears to have over-complicated their lazy loading. For the modern web, a regular image element with the loading attribute set to lazy is enough: <img src="[regular image URL]" loading="lazy">
The site also uses a <noscript> element which is supposed to contain elements that a browser without Javascript can render, but even this element contains image markup that requires Javascript to display.
The site config above should fix this for Full-Text RSS by renaming a few attributes.
Thank you very much for your expertise in getting to the nub of this.
I noticed that you tend to use find_string / replace_string rather than doing both with just replace_string. Do you have any rationale for this or is this just a personal preference?
It’s mostly personal preference, but also the way Full-Text RSS parses replace_string([string-to-find]): [replacement] is quite rudimentary (splitting on the first colon found). So if [string-to-find] contains a colon, it won’t work.
So to replace src="data:image, you won’t be able to write replace_string(src="data:image): disabled-src="".
