Hi!
If item_url contains space or spaces it is not included in parsed items. If you set item_url=0 when item is included in parsed items.
Thanks.
Hi!
Thanks.
Hi there, I’m afraid I don’t understand. Can you provide a URL to a generated feed you’ve created with Feed Creator and describe what the result should be.
Hi!
Missing one item, showing 31 items. a tag contains space in URL.
Showing all 32 items.
You need enable more default max value. At least 32 items.
Thanks.
I’m not able to reproduce this, I’m afraid. If I set max values to 50, I get 32 items using either set of parameters (with and without links).
I’m using Feed Creator 1.2 on my own server.
Hi there, version 1.2 was released around 5 years ago. There have been a number of improvements and bug fixes related to URL handling since then. I tested with version 2.1, the latest version of Feed Creator.
Hi!
OK I will check out new version (changelog.txt) and report later.
Thanks.
