I managed to set all parameters, except the correct URL parameter:
The parameter “a” extracts the wrong URL of the first linked category. What I need, is the last URL of the entry:
<a class=“more-link” href=“correctURL”
How to set the correct parameter for this case?
You should use h2 a instead of just a for item_url:
Try this:
Alternatively, you can keep what you have and strip category links:
…and you can simplify further by removing item URL and item title parameters:
Hope that helps.
In the end these variants look all the same to me. Thank you soo much, this helped me a lot. And also I could learn how to remove HTML elements.
No problem. Happy to help. The 3 links should all produce the same result, I just wanted to highlight different ways you could use the parameters to select the same items.
