Some return posts, give me results that i dont want them to appear.
How can i do that, by keyword ?
Example: The post description give me “sex”, so i want that post to not show on the result.
Is possible to do that ?
Thank you.
Regards
Thank you.
Regards
Hi there, thanks for the question. We don’t allow filtering results at the moment, so you’d have to do this either using another service, or see if your feed reading application can filter results based on keywords.
