http://pastepad.fivefilters.org/ is cool! But if I paste an article in it, there will be no title for it. How can I add a title? Thanks!
Hi Zhang, the title should me formatted as Heading 1. You’ll find this in the Paragraph Format drop down (the default option in that list is Normal). Hope that helps.
It works! But not exactly intuitive as evidenced by repeated title requests.
