How to remove only element and keep the content inside it.
وذكرت مراسلة "قدس برس" أن قوات الاحتلال استنفرت في حي "رأس العامود" ببلدة سلوان جنوب المسجد الأقصى، عقب قيام شبان فلسطينيين بإلقاء زجاجات حارقة باتجاه حافلة صغيرة تقلّ مستوطنين، ما أدّى إلى اشتعال النيران فيها.
I have tried many with no luck :
find_string:
replace_string:
Appreciate your help!
Hi Mohammad,
Please try the following:
find_string:
replace_string:
find_string:
replace_string:
Thanks for your reply.
I have tried it and it is not working, I have also tried that and didn’t work too:
find_string:
replace_string:
find_string:
replace_string:
and also
find_string:
replace_string:
find_string:
replace_string:
Mohammad
Hi Mohammad, have you enabled debug mode to see if your site config file is actually being used? The debug output will tell you if your file is being loaded.
Yes I have doubled check.
Mohammad
Hi Mohammad, if you can supply the following information, we can try to see if we can figure out what’s going wrong:
- Copy of the debug output
- Copy of your site config file
