For some reasons i need to replace some characters in the items title with nothing
lie this :
replace (‘a’ ‘’)
how can i achieve this?
lie this :
replace (‘a’ ‘’)
I have tried this:
title: replace_string(a): b
in the site patterns with no luck
adnan
Hi Adnan, you cannot replace strings within the title, but you can replace globally. So instead of:
you will have to do:
Of course this might affect content in the body too.
Well, i have tried this
replace_string(exapmlewordavailableinfeed): adnan
to test tried to put it after
prune: no
not worked in both body & title, in the end of the file also not worked in both body & title
my version is 2.8, my feed language is arabic
this is my file
prune: no
body: //div[@class=’ main_focus’]/img | //div[@class=‘main_content_ip’]/p
strip: //iframe[@id=‘iframe1’]
Please note that:
I need to only use this for some symbols like “ & ” not for words
I tried all of it with no luck
adnan
Hey, Somebody help!!
adnan
hi Adnan,
my suggest, u better using external service to modified, becaus, i use ver 3.2 still can’t replace_string to title… except u have qualified skill on php language, u can modified from makefulltext.php and libraries/*
Martin
@Martin
Sorry i don’t understand you can you please more specific
My version is 2.8
I have no problem with replacing in global if the replace will replace the title & the content because i will just replacing some symbols
adnan
@adnan
i use ver 3.2
when the content want to replace have some symbol on title/content like (&, %, #, ~) it never execute with the engine (for some domain). so, i use yahoo pipes service to replacing that for fast cleanup.
that’s my opinion
Martin
