hi all
There is a link below to see the content…
PishkhaanSidebar.serverResponse([‘
simple title
’,'armanI want to be removed “_Thumb” from the image URL _Thumb.
I know I should use STRIP on site config, but do not know how
hi all
simple title
If you would like to remove _Thumb from the image URL so …Omoomi_Thumb.jpg becomes …Omoomi.jpg, you can use find_string and replace_string in the site config file for this site like so:
find_string: _Thumb.jpg
replace_string: .jpg
If you would like to remove the image completely if it contains _Thumb.jpg, you can do the following:
strip: //img[contains(@src, ‘_Thumb.jpg’)]
