When looking into the code of a YouTube rss feed (https://www.youtube.com/feeds/videos.xml?channel_id=UCxxxxxxxxxx), you often have the problem that the latest entries are “Premiere”, which means they will be published much later. So the feed reader should receive the entry not before the video has already been published.
Is it possible to remove all entries which have a “views” number between 0 and 999, or in other words: Is it possible to keep those entries with at least 1000 views?
I was thinking of this criterion:
in “media:statistics”, the number must contain 4 digits. When it rises above 4 (10 thousands or higher), then it was already forwarded to the feed reader.
