I was curious if there was away to combine more than 20 feeds using the feed creator tool? Would it work for me to combine 10 feeds into 1 feed, and repeat that 3 times so that I have 3 feeds and then combine those 3 into 1?
thanks!
Adam
thanks!
Adam
Hi Adam,
Might be possible, but the feed will be very slow to load. Our tool will have to make 30 requests and process them all.
There’s also the possibility that we’ll limit the number of feeds in our free, hosted service. So if that’s a concern, you might want to consider the self-hosted version.
