failed to send for kindle in china
I use your iOS APP to send Safari webpage to kindle.cn, but I always failed to receive. I check your pushtokindle APP, after I set up my xxx@kindle.cn account, but the destination column shows the account is xxx@free.kindle.com. So I think your iOS APP doesn’t support kindle in China.
Hi Johny,
We do support kindle.cn sending, but we should make this clearer in the app. To send to kindle.cn addresses, you need to tap the ‘Send to’ field in the Push to Kindle app (open it from your app list, not via the share menu) and you’ll then see a list with the following options:
  1. Kindle
  2. Kindle (China)
  3. Pocketbook
If you select ‘Kindle (China)’, then we’ll use the ‘kindle.cn’ domain for sending and the ‘Desintation’ field in the review section will reflect it too.
Let us know if you have any trouble.
