I am currently using the installed version of Full-Text
When processing a feed like:
https://groups.google.com/forum/feed/alt.sports.baseball.chicago-cubs/msgs/rss.xml?num=15
I would like to pull the first link in the portion of the feed for further article extraction in the combined feed.
Is this possible?
TIA,
Joe
Hi Joe, I can’t see a link in any of the description elements in that feed. Can you give me an example of what you can see?
This would be an example item:
**Notice that there is a link in the description, I would like to be able to parse that link, or anything that looks like a link(with or without href tags)
Continued Rejection Despite Approved UK Charity Status
https://groups.google.com/d/msg/googlefornonprofits-discuss/Da-A8JoqODg/ZxZs62ZcduUJ
Hello My partner runs a charity that is listed on the charity commission website but upon applying it gets rejected. http://apps.charitycommission.gov.uk/Showcharity/RegisterOfCharities/CharityFramework.aspx?RegisteredCharityNumber=1157356 There is no reason given and it is rather frustrating. I wis
https://groups.google.com/d/topic/googlefornonprofits-discuss/Da-A8JoqODg
Richard Young
Tue, 01 Jul 2014 10:31:30 UTC
Thanks,
Joe
Joe M
