Whenever I put a url in this new instance, for article extraction the Url is altered from “http” to “Sec” see the example below:
Before
https://news.ycombinator.com/rss
After
sec://news.ycombinator.com/rss
Output
The output is pure gibberish, can anyone tell me why this is happening and what I can do to fix it?
@BocciaMan It is absolutely normal, that FTR is changing https: to sec: that is no problem.
But your feed aggregates articles from different sources, with different html formats. Some of these sites are catched very well, while other sites/hosts may need a config file.
So, if you get rubbish you should post the article link, not only the feed link.
Glad it’s resolved. To explain why we change ‘https://’ to ‘sec://’, it was done a long time ago when users hosted Full-Text RSS on different types of shared hosting. Some of those hosting providers automatically flagged any URL that contained another URL - identified by the scheme ‘http’ or ‘https’ - as suspect. So when we generate URLs we use ‘sec’ and then internally treat it as ‘https’.
But as @HolgerAusB says, that should not affect the result you see.
