creating pdf
when creating pdf of one particular article, result would only produce 1/3 of said document, 3 pages, even though there was enough content for more. Tried a number of different ways to ‘trick’ the system, so that all of the article would be converted, with no change in the result - same 3 pages only. Help and ‘why’ would this happen?!
Here is the article with the problem: [https://hbr.org/2018/04/how-perfectionists-can-get-out-of-their-own-way]
Thanks
Hi there, thank you for reporting this. We’re going to look into this. Our plan is to move PDF Newspaper to use the newer kind of PDF generation we’re now using for Simple Print. I tested with that and this particular URL seems to work okay. Please give it a go: https://pdf.fivefilters.org/simple-print/
Even though this is an old post it, it seems to be the same problem I am having. I even tried using the url for Simple Print and the same problem occurs. Here is the article url This Physicist’s Ideas of Time Will Blow Your Mind
When I try to use push to kindle to convert this article to a pdf, only the title and first paragraph are generated.
Thanks for reporting this. We’ve fixed extraction for this site for both Simple Print and Push to Kindle.
If you try the same URLs you tried before, you might have to wait a couple of hours for the cached copy to update. But if you use a different URL or use our Push to Kindle browser extension, the article content should get through already.
