Hi, do you have a place setup where users could contribute to site config files? E.g. I’ve found some changes to the HuffPost site that would need to be reflected in the site config file. I’ve already copied the config file into the custom folder on my own installation, but I’d be happy to commit the changes to the rest of the users, thus also getting the changes back into standard/ folder.
Cheers,
Martin
Hi Martin, that’d be much appreciated. The site config files which appear in the standard folder are all on GitHub: https://github.com/fivefilters/ftr-site-config - since Full-Text RSS 3.2, if you enable the admin area and use the update tool within, it’ll be updating from this repository. We made a blog post about the change which you can find here: http://blog.fivefilters.org/post/44162368340/site-config-github
Let me know if you have any trouble with it.
