Is it possible to match body with substring or id or class?
Did you mean substring of the id or class attribute? If so, something like this should work:
body: //div[contains(@id, 'substring') or contains(@class, 'substring')]
If you want to match an element which contains some text, you can try:
body: //div[contains(., 'some text')]
Hope that helps.
