Remove Article if less than certain length
Wondering if it’s possible to simply skip an article if it’s less than a certain length? I keep getting articles that are very short (only 5 - 10 words) and I don’t want to use them.
Thanks in advance for any help you can provide.
Hi Clayton, we’ll think about adding this feature in a future version. At the moment it will require modifications to makefulltextfeed.php to achieve this.
Thanks Keyvan.
Clayton Crooks
