Hello,
I just tried Full Text RSS V2.9.5 on Synology and the V3.2 that I just bought on OSX Maverick.
Both leads to the same result : no name and empty feeds
Can you help me ? I didn’t find any install manual, and can’t find what I did wrong.
Here is my conf on OSX:
Your version of Full-Text RSS: 3.2 (Full-Text RSS version check :You’re running the latest version!)
Your version of Site Patterns: 2014-04-24T15:12:56Z (Site Patterns version : Your site config files are up to date!)
In the compatibility test, I only miss Tidy, which shouldn’t prevent Full text rss to work
Full-Text RSS 3.2: Compatibility Test:
Test Should Be What You Have
PHP 5.2.0 or higher 5.5.10
XML Enabled Enabled, and sane
PCRE Enabled Enabled
Zlib Enabled Enabled
mbstring Enabled Enabled
iconv Enabled Enabled
Data filtering Enabled Enabled
Tidy Enabled Disabled
cURL Enabled Enabled
Parallel URL fetching Enabled Enabled
allow_url_fopen Enabled Enabled
I have created a custom_config.php to set an admin password, to access the admin area and update patterns
Now, when I create a feed with http://appleinsider.com/appleinsider.rss, it launches my rss reader (on OSX or only ipad), and I have a no-name and empty feed.
Generated URL is http://localhost:8888/FTR/makefulltextfeed.php?url=appleinsider.com/appleinsider.rss&max=5&links=preserve&exc=&submit=Create Feed
When I check the “debug” check box, it seems to be ok, and the JSON returns text
When I try with Full text rss on the official with site, it works correctly
What did I do wrong ? I really want to be able to use your software that I find useful (hense bought)
Best Regard,
Francois
