I am trying to just strip out the links from the feed
I have set up a custom site pattern with " strip: //a " inside it but it doesnt work. Am I doing something wrong?
Thanks
Thanks
Hi Cam, the line
strip: //a
Should do what you want. Please make sure caching in Full-Text RSS is not enabled when you’re changing site config files, and make sure the file is named correctly. E.g., if extracting from www.example.org or example.org the file should be named example.org.txt - if from a subdomain, e.g. sub.example.org, the file should be sub.example.org.txt or .example.org.txt
Let us know if you still have trouble.
