I’m trying to strip all the links on this webpage :
and a lot of them didn’t appear because they are inside (ul) and (li) balises and i don’t know how I can add them.
If I use prune: no they appear but on this page :
I see the poll at the end and I don’t want it.
thanks you for your help!
PS : Is there some kind of nostrip or something else to make everthing appear in the body except the undesired text or picture?
I’m sorry for the links it was these ones
and
colibri
Hi Colibri, In addition to using prune: no, I suggest you select the content block as body and then use the strip commands to remove elements, such as the poll, that you don’t want. See http://help.fivefilters.org/customer/portal/articles/223153-site-patterns
